Front oil leak
Old Feb 27, 2008 | 08:27 AM
btc50's Avatar
Front oil leak
My 91' 22RE pickup is dumping a enough oil out of the front oil seal that the entire front diff is shiny with oil. I'd say it's probably a noticeable drop every 300 miles. I did a timing chain job and replaced the front seal. I am pretty sure I packed it right, but I won't swear to it. What are the chances that pulling the crank pulley (I have the stuff to do it) and repacking the seal will slow / stop the leak?
Old Feb 27, 2008 | 09:12 AM
4runnerx3's Avatar
You need to pull it off and check to see if you have a groove worn in it by the seal, might need to put a sleeve over it.
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
