Front hub gasket name/part number
I've been all over this forum looking for a name or number of the non-reusable gaskets/seals that I'll need to replace while doing my rotors. I'm not doing bearings or oil seals, I just need the seals that I'll have to replace after I get the hub off to replace the rotor.
The FSM doesn't specify a part number, and I can't seem to find what I need on RockAuto.
Any help?
Any help?
Front Axle Outer Shaft Flange Gasket 4342260010 this is the one under the hub. Free Wheel Hub Gasket 4353160010 this is the star gasket that goes under the dial.
You should be able to get them at dealership they're pretty cheap and usually stocked.
Sep 4, 2015 09:27 AM
