Can't figure out this darn coolant problem...
Hey guys. I feel like I've exhausted myself trying to figure out this darn coolant leak. Quick history (in the last two months):
Upper rad hose leak = tightened clamps.
Head gasket leak = replaced head gasket
Radiator cap leak = new oem rad cap
Upper rad hose leak = new oem radiator hose + new clamps
Now the new radiator cap leaks and, also, under the clamp where the upper radiator hose meets the radiator. It's small drops and splashes here and there, so it hasn't ever overheated. What's super strange is that my overflow has never had coolant in it - even though the overflow hose works great (blew through it). And the overflow has no leaks. I haven't added any coolant in the last two months and the radiator is always full to the top when I take off the cap and the overflow reservoir is always empty.
But after every start/drive there's coolant splashed around the cap and under the upper hose... leaking onto the skid plate.
It's driving me nuts. Do I have a pressure issues?
Sounds like you have pressure issues.. which engine do you have? Stock rad cap for the V6 is 13 lbs. Seems like your radiator itself is gunked up if pressure is only building at the top of the rad. You can get one for around 200. Are there any pinhole leaks at the top or anywhere?
Just an FYI. That is not an overflow tank, it is a reservoir it is ment to have something in it you should fill it to the line on the side that says "cold".
Other things to checkout would be the cap is in spec and opens at the right PSI. The thermostat is the OEM dual stage, and fully opens at the correct temp.
If it is leaking and always full there must be air in the system, or something else filling that space either way it's bad.
Thanks Co94. I'll fill up the reservoir. I'm just hoping that I didn't screw up - putting the coolant system back together (got air in it?). Again, no overheating and it's running fine - I'd think that I would notice air in the system?
Blamalam
Mar 12, 2022 07:34 AM
jasonty
41
Dec 23, 2018 01:00 PM
