front differential
Old Jan 3, 2011 | 09:49 PM
InvaderTrax's Avatar
Originally Posted by highonpottery
...As for the bearings, from what I recall it's the ADD tube that has needle bearings vs a sleeve on the non-ADD tube...
So far, what I can gather is the 86-89 nonADD diffs had a sleeve in the diff that the stub rides on. The 90-95 ADD diff has needle bearings. No idea if the 90-95 nonADD diffs have needle bearings or sleeves. I've heard people say that if you swap the nonADD shaft into an ADD diff, that you need to remove the needle bearings and press in a sleeve. I mic'd the ends of each shaft and they were identical, so I lift the needle bearings in. Haven't had a chance to really test it out other than 2 minutes in a field, but I doubt it will hurt anything. If it does, I'll be sure to post it
Also, adding the nonADD shaft to an ADD diff requires installing a seal where the shaft slides into the diff
Ladythump
22
Nov 9, 2015 08:53 AM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
ripp96
Jul 25, 2015 02:32 PM
scottyg486
Jul 19, 2015 05:34 PM
AaronM
Jul 8, 2015 07:15 PM
