Front diff offset
Old Jul 7, 2010 | 11:04 PM
CitrusTheDragon's Avatar
Originally Posted by scuba
Measure the jack tube and divide in 2. Theres your offset.
what is a jack tube????
Old Jul 7, 2010 | 11:20 PM
scuba's Avatar
It's the thing that goes from the diff to the drivers side CV axle. On an ADD truck it'll have a actuator on it. It's the tube on the right of the picture hanging off the differential.
It's what allows the cv axles to be the same length on each side. The side of it that is bolted to the diff is driven by the diff, and the other side drives the cv axle. Simple technology.
Old Jul 8, 2010 | 12:03 AM
DeathCougar's Avatar
being that his is an 86, it won't have ADD so the top tube is correct.
However, I still fail to see the correlation between IFS and Landcruiser axles. Exactly WHAT are you TRYING to do?! The diff is offset to the passenger side to accommodate the pass side Tcase drop, but unless you plan on doing a SAS, you won't be fitting a Landcruiser anything in there.
Landcruisers through 97 use a SFA, and everything 86+ truck/4Runner is IFS.
Old Jul 8, 2010 | 12:26 AM
thook's Avatar
You guys are brutal. Glad I'm not a newb. A bewb, maybe, but not a newb. And, being a bewb, I like kissing myself. Is that wrong?
Old Jul 8, 2010 | 05:02 AM
  #25
whorider's Avatar
If your talking about putting a solid axle in. It doesn't really matter that much. If your talking about putting a different IFS diff. in, you might want to consider leaving it alone. Or putting another stock one in. Your post is confusing about what the end result is. 9.5" Ford axle? 9.5" Tundra axle? Rock Assault custom housing?
What are you trying to do? Explain basics, not what gear ratio and locker you think you might put in someday.
On a side note:
If you have that little of time to research YOUR project and want others to do it for you. How do you plan to wrench on your rig?
Old Jul 8, 2010 | 05:50 AM
  #26
c0ugar69's Avatar
I think what the dragon is trying to do is figure out the off set for the front axle. He is ordering 65 inch solid axle and needs to know the offset of the front diff for ordering, at least thats what I get out of his post. I dont know myself since i have the IFS in mine. someday I will get a SAS.
Old Jul 8, 2010 | 08:26 AM
  #27
I am doing a custom axle not a landcruiser and it will be a sas. I understand why it's offset. Couger69 is right, sorry to confuse some of u guys
Old Jul 8, 2010 | 08:31 AM
  #28
On a side note:
I thought I had been clear and people complained about it. So I will just be removing that part to lessen confusion. It will be a totally custom axle just using a landcruiser diff.
To the side not I don't want other people to research it for me, I ask the questions in case somebody knew or could get the answer quicker then me. When I get to my truck I will measure it out myself.
  #29
scuba's Avatar
Curious.
Are you building a diamond? Or ruff stuff housing? Or what?
Old Jul 8, 2010 | 08:34 AM
  #30
Curious.
Thought of going with diamond, but I have a guy here that does our race axles, says he can do it cheaper
Pic so it happened
Old Jul 8, 2010 | 09:22 AM
  #31
I had the result clearer and people complained about that so I will just be removing the part.
I think most of the confusion in your threads comes from sentences like this. This sentence doesn't make any sense. What result, and what part are you removing?!
Old Jul 8, 2010 | 09:29 AM
  #32
merfal's Avatar
I'm mildly confused as to what's going on here...
Old Jul 8, 2010 | 09:37 AM
  #33
I am not so good with the english language. I am also not so good with people. So I will try and clear things up the best I can
Old Jul 8, 2010 | 09:38 AM
  #34
Asked a question. Didn't word it right. Got put in my place. Pissed people off. Now I think we might be getting to the bottom of it. Slowly
Old Jul 8, 2010 | 10:01 AM
  #35
scuba's Avatar
Are you Russian, too ?
Old Jul 8, 2010 | 10:09 AM
  #36
No I am a grunt, fail english, barely past school, its a wonder I made it in college. Great with math angles and building. Stuff that makes since in my head. The race car is proof of that.
Old Jul 8, 2010 | 10:10 AM
  #37
thook's Avatar
Nice build. Goes well with the drapery.....
Old Jul 8, 2010 | 04:48 PM
  #38
whorider's Avatar
It really doesn't matter that much at all. As long as the diff. is on the passenger side. You could just model it after a D60 or any other full width front axle.
Once again its not that critical.
Old Jul 8, 2010 | 07:13 PM
  #39
BigBluePile's Avatar
oooohhhhh, it's a solid axle!
Old Jul 8, 2010 | 07:15 PM
  #40
will be when i am done
