Front diff/axle nuts
Old Aug 27, 2016 | 04:36 PM
mcdonnell's Avatar
I have been searching for the part numbers for the nuts for the front axle. More specifically the nuts that attach the axles to the differential. If anyone can help, I would absolutely appreciate it!!
'87 p/u 22r
Thank you!
Old Aug 28, 2016 | 02:34 PM
wyoming9's Avatar
Your talking about the nuts that go on the differential side of the CV axles
Where most of us knock out the studs and put bolts and nuts in
I can`t recall if they are M10 or M12 without looking
They will be M12x1.25
Old Aug 28, 2016 | 03:08 PM
ewong's Avatar
As a side note 12x1.25 is a JIC standard
The (typically easier to find) DIN standard 12x1.5
Also note that DIN tends to use larger "hex head" for a given diameter
TheEastBeaster
Mar 7, 2016 06:11 AM
Snowking
Jan 29, 2016 02:03 PM
toyrunner
Nov 5, 2002 02:14 AM
