frame repair
Old Jan 9, 2007 | 11:07 AM
Sandman's Avatar
frame repair
The front cross member on my frame (where the frame horns join) is rusting out. A long time ago I installed an aluminum cow catcher and I guess the different metals got too comfy and started rotting. The rest of the frame is great - can I just cut this piece off and re-weld some thick square stock in there? Anybody face this before? (90 4runner).
Old Jan 9, 2007 | 12:36 PM
InternetRoadkill's Avatar
A solid piece of iron pipe or square tube would prolly work rather well. Just get the spacing correct. You may want to put some end plates on it if the new tube doesn't match the frame edges exactly.
Old Jan 9, 2007 | 01:05 PM
gonzo's Avatar
If your talking about the crossmember under the radiator yes. I have done that using 1/4"x 2" box steel.
Good luck
justdifferentials
14
Jun 11, 2017 08:36 PM
indawire
Nov 29, 2015 05:05 AM
djpg2000
Sep 7, 2015 10:36 AM
