Found the oil leak--oil pan removal?
Old Dec 31, 2007 | 07:15 AM
morrison's Avatar
The major oil leak on my 94 3.0 4-runner suddenly got so much worse it was easy to see it coming out between the oil pan and the block all around, not just in back. Looking carefully I can see that someone used a cork gasket and that is why the bolts were loose. I need to re-do it with the proper sealant.
But can the pan be taken off without pulling the engine? It looks like I could get it off by removing the steering tie rod, anyone know?
Thanks!
Old Dec 31, 2007 | 09:51 AM
leiniesred's Avatar
I helped a guy who used to (maybe still does) post on here who tried this.
He had a TON of the front end apart when I came over with the tie-rod puller!
We were able to get the pan out eventually, but it wasn't the easiest way.
You really want to pull the front differential out of the way. It is only 24 bolts. including the skid.
Old Dec 31, 2007 | 10:09 AM
DeathCougar's Avatar
Or you can pull the 4 engine mount bolts and raise it up enough to get the oil pan out.
I would suggest pulling the diff or at least getting it out of the way via lowering it. That will make the intall SOOOOO easy.
Old Dec 31, 2007 | 10:54 AM
toytech76's Avatar
Yes...I say drop the front diff so you can drop the pan past the pickup. Go to toyota and get a tube of black FIPG. The stuff is the best sealant. There is also a windage tray between the block and pan you should reseal since you are there
Old Dec 31, 2007 | 01:21 PM
morrison's Avatar
OK, thanks guys. I'll tear into it in 2008.
Happy New Year!
JIM
Old Dec 31, 2007 | 03:07 PM
neoworm0's Avatar
HaHaHaHaHa.
Damn that makes my SAS worth it right there. LOL! Good Luck with that. I don't envy you.
Old Dec 31, 2007 | 03:16 PM
Targetnut's Avatar
you can unbolt the front diff housing from the frame and leave it attached to the axles and just let it hang down, this will give you the room you need.
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
Gamble_STi
Jul 7, 2015 07:54 PM
HRDC0R19
Jul 5, 2015 06:43 PM
