Fixed my clutch problems!!!
Old Feb 23, 2007 | 05:28 PM
hektikwon's Avatar
I posted a little while back about hard shifting and tranny problems. Well I just changed a clutch on a 2000 higlander edition 4runner. I noticed that the stock disc was in the opposite way I had just installed mine. From reading the service manual it sounded as if the side with the springs sticking the farthest out from the disc went towards the tranny. Maybe I misunderstood but actually that is flat with the spline sticking out the farthest goes toward the tranny. The springs should sit in the flywheel. I know I read some threads when people were confused about the correct way because the disc I've seen don't say which way to put them . The one that I pulled was the original and it was label. Hope this helps.
Now I don't get grinding when going into reverse, it shifts much smoother, and there's less slipping.
Old Feb 25, 2007 | 09:47 PM
Elton's Avatar
good info
Old Feb 25, 2007 | 11:43 PM
DeathCougar's Avatar
hopefully you checked the disc for damage, having installed it backwards?
Old Feb 26, 2007 | 03:36 AM
TNRabbit's Avatar
I feel your pain; I've found SO MANY things that have been installed backward from the factory or a "qualified" service technician....I'm constantly amazed by it.
Old Feb 26, 2007 | 01:49 PM
hektikwon's Avatar
I just installed the disc before christmas so it was fairly new. It wasn't cracked just a little worn from slippage on one side so I cleaned it, the flywheel and the cover up real good and slapped it back in there. I have noticed much less slippage and my pickup is better.I can't belive I installed it backwards.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Yota.Jay
Jul 23, 2015 08:08 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
ptb12
Jul 5, 2015 01:49 PM
