for the first time in 3 years, my rig overheated!
Old Oct 7, 2008 | 01:44 PM
blackspyder's Avatar
Originally Posted by KevinInSac
I must say, your very first problem was your driving habit. You're pushing the engine hard-ish at 4500 rpm. Then by dropping it all the way down to idle, you're making it really hard for that fan to move air through the radiator (most likely nullified by the fact you are moving) but more importantly, that water pump is turning very slowly now too. To make it even worse, you shut it down immediately. You should have let her idle on the side of the road and let the water pump/fan put in some work. By shutting her down, you're leaving your whole system full with near boiling water. No bueno. This can lead to a worse case scenario cracked block.
Uhh.... cracked blocks from overheating "usually" only occur when "crack"heads put Ice cold water in the radiator. Head and Intake Warping is more of a real threat. As for shut it down or let it run.... Shut it down, once its over heated the damage is done allow to cool slowly to avoid as much warpage as possible
Old Oct 7, 2008 | 01:59 PM
ozziesironmanoffroad's Avatar
okay, just finished the compression check. its 145-150psi across the cylinders with all the plugs out. so pretty even. im ruling OUT the head gasket. however.... i got a good look at the plugs. not so healthy looking. i put them in back in may and didnt drive much until september. heres a pic of them.
problem? or do those look almost normal for a few months?
Old Oct 7, 2008 | 03:08 PM
okay, its the coolant hose that goes from the 2 sensors into the engine. it will be replaced tomorrow. i just drove it a little bit then parked it, wasnt leaking. so i pinched that hose, and it started sprayin again. so yeah, figured out my problem with the help of YT guys. thanks
Old Oct 7, 2008 | 08:40 PM
replaced the spark plugs, just got the cheapest autozone special, theyre freaking MOTORCRAFT! FORD! i was pissed, but then i was like, eh its only for a few days, its ok. so i put em in, and, keeping in mind that it was run ONCE this morning for maybe 3 minutes, then just sat outside all day, started it. it started on the first crank! and does so now, what ive NEVER seen it do. i guess ford knows how to make spark plugs... im debating about leaving them in...
Old Oct 7, 2008 | 10:46 PM
  #25
Alex 400's Avatar
why not? there in, they work good, who knows what you gas milage will do?
Old Oct 8, 2008 | 07:08 AM
  #26
cant track my mileage until i replace the speedometer cable, lol. though i have noticed since i dropped my air pressure from 35 all around to 32 all around i have gotten WAY worse mileage. but just to get an opinion, do those spark plugs in the picture look okay, or do they look shot? and if shot, what would cause them to be shot within 5 months?
Old Oct 8, 2008 | 08:06 AM
  #27
Alex 400's Avatar
To me they all look a little wet, and the ones on the left look a little rusty, but if they worked they worked. Even if they worked, looking like that, i probably would have replaced them, just as you did.
Old Oct 8, 2008 | 08:07 AM
  #28
yeah. and on 22Res, is 5 months pretty normal to have to replace spark plugs, or am i running a little rich?
Old Oct 8, 2008 | 10:14 AM
  #29
just a 22re's Avatar
good thing you found your problem wanna fly out here and stay here a few days and help me out now lol and the way it looked i though it was the intake gasket when we talked sounded just like when mine gave out the 3-4 diff times it did that. lol
so in your case its the tolet bowl over flowing lol
Old Oct 8, 2008 | 11:08 AM
  #30
basically ya. i replaced the hose, and now just waitin for my engine to dry (i sprayed the engine with water from the hose, and i dont want to fry anything) then im gonna go warm it up and go drivin and see if it starts overheating or leaking. if i could get the time off i would bro, but i cant get the time off. im not even sure if ill be able to get a week off for xmas and my bday (same week). but im deff. gonna fly out there sometime, you can show me some good wheelin spots out there. but yeah, the hose was definitely shot. there was a HUGE crack in it.
Team420
Jan 12, 2021 04:57 PM
the1998sr5
Oct 19, 2016 12:48 PM
vasinvictor
Jan 20, 2016 12:39 PM
marcusSRG
Jun 27, 2015 07:13 AM
