fan ripped right off 3.0!!!!
Hey guys i was driving yesterday and i start hearing a grinding noise from under the hood. All of the sudden i hear this terrible noise and then all the acessory light s light up and no power steering. Right away i thought i blew a belt. So i pull over and look down and the whole fan and where it bolts to tore off!!! WTF!!! then i notice a huge hole in my radiator. What happened?
took another look at it and it looks like a bearing went bad on the place where the fan bolts to. I think it is the fan pulley bracket. Anyway i just ordered a flex-a-lite 165 fan and i am going to put it in tommorow. Well i also had to buy a new radiator, 186.00 new electric fan, 253.00 to get it overnighted, and new belts for the a/c and alternator, don't know how much they will be. And a bunch of agrivation. All because of some bearing on a cheesey metal bracket(that by the way i called toyota and they want 798.00 for
) I hope that the electric fan will keep things cool, i have a auto tranny and a/c.
Similar thing happend to me. My fan pully bracket bearings went bad luckily I caught it before it went to pieces. The flex-a-lite will keep you plenty cool. The stealership was asking about that same price when I talked to them, its because they dont really make that piece anymore. You can find alot of them cheap on Ebay.
X2, not sure what year you have but here's one for 88-92 http://cgi.ebay.com/ebaymotors/88-92...QQcmdZViewItem
You will probably still need one even with the e-fan, unless you get some different drive belts and bypass those idler pulleys.
long story. I got stuck in a huge mud pit. My truck was acting weird and i was at work one day about to leave for home when I heard a crunching kind of noise. I looked under the hood and my fan was spinning kinda side to side. It would correct itself for a few moments then act up again. I took it all apart and found bad bearings in the idler pully. My guess is i got some good dirt mixed into the bearings that eventualy wore the bearing out. If you do any offroading i would suggest getting a electric fan to protect against this and also keep you cooler.
hey guys can i just take the whole pulley bracket off? or cut it down, i know i will need new smaller belts because of the missing fan pulley. does anyone have a pic with the pulley bracket off? can i just make a piece of steel with a plasma cutter kind of like a block off plate?
thats nuts....
