Failed smog. Any tips or suggestions please?
Old May 18, 2010 | 07:07 PM
dark_fairytales's Avatar
first off if your o2 is older then one year that has to be replaced.
second how old is your cat. if more them five years time to get a new one, but there is a hitch. you need to go to NV to get or you will screw your self with the new laws that changed in 2009. if you get a cat. in cali it must meet obd2 specs. and cost a lot. plus if you use an obd2 spec. cat. then the truck also has to past stricter emissions. I got screwed due to this and now i drive with 09 tags.
Any way for you to get an older cat. you have to go to NV and even then you will need to make it look old. if it looks new you will fail the visual inspection. as the new cat. require a CARB and manufactures serial number.
IF you have any more questions, PM me and ill get back to you. ive had a lot of experience with this bs for years.
Old May 18, 2010 | 07:32 PM
Teuf's Avatar
No one checked my Cat, when i failed then passed....?
Old May 18, 2010 | 07:44 PM
is your truck a cali or fed truck
and it only matters if you replaced the cat.
Old May 18, 2010 | 07:54 PM
Teuf's Avatar
I came from NH, failed here, replaced cat from one i brought from NH, fed cat 149.$. Then i passed.
Old Mar 24, 2011 | 12:40 PM
  #25
bkmoos's Avatar
smog high CO% = faild ( help)
i have a 86 4runner SR5 ,22REC ,EFI and it failed smog with a high co% eveything else was good
Lodi,Ca. smog
co2 14.1
o2- 0.0
hc- 105
co- 1.07 failed
no- 411
15mph- 1544 rpm
engine is 3-4 years old since rebuild
oil,air filter is just changed
any options
thanks.
Blamalam
Mar 12, 2022 07:34 AM
westonian18
May 1, 2020 06:38 AM
Jason Webber
Sep 2, 2015 03:30 AM
rondogracing
Engine Swaps
16
Aug 24, 2015 03:02 AM
timmJ
Jul 7, 2015 02:01 PM
