Engine/Transmission Separation Problem
Old Jan 24, 2007 | 06:14 PM
jaysTOY's Avatar
Hey guys, first post here.
I have a stock 87 Toyota Pickup, 2wd, 22R-E engine with an automatic transmission. I am in the midst of pulling the engine out but I can't seem to get the engine apart from the transmission/torque converter. Right now there is about a 2 inch gap between the two (enough that the alignment pins are out). Do you have to unbolt the flywheel from the torque converter? Doesn't look like there is room to do that though.
I've tried various combinations of lifting or lowering the engine while raising or lowering the transmission but no go. My buddy and I have tried using crowbars and pry bars but no luck. Are there any secrets or rules of thumb for this? The Hanes manual wasn't much use.
Much appreciated!
Jason
Old Jan 24, 2007 | 06:33 PM
mt_goat's Avatar
Yes, you should unbolt the drive plate from the torque converter. It is possible to remove the tranny without unbolting the TC but its harder and you may damage the seal on the TC. There should be enough room to get a wrench on one bolt at a time, you just have to rotate the crank around to get them all. When going back together take note that one bolt is different than the others, put that one in first.
Old Jan 25, 2007 | 09:00 PM
jaysTOY's Avatar
That did it! Thank you for your help!
88sasturbotoy
Jan 30, 2026 01:57 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
msane99
Jul 17, 2015 10:13 AM
