Engine Code 51 22re
Old Jan 29, 2008 | 08:22 AM
WTAllstar's Avatar
Engine Code 51 22re
Ok, check engine light gives me engine code 51. Here's what I found about that code.
SWITCH SIGNALS
IDL (tps) CONTACTS OFF, NEUTRAL START SWITCH OFF, A/C SWITCH "ON" SIGNAL TO ECU
WITH DIAGNOSTIC CHECK CONNECTOR SHORTED
--A/C SWITCH/CIRCUIT
--A/C AMPLIFIER
--TPS/CIRCUIT
--NEUTRAL START SWITCH/CIRCUIT
--ECU
Here's a little history. It's an 88 4runner, no A/C, recently swapped the motor. Now I am having a hesitation/surging feeling under a load. Along with lack of power and low gas mileage. It kind of feels like the engine could be starved for fuel. The timing is on, fuel pump works, so I'm thinking it could be a sensor or a vaccum line that's not connected right, and is throwing off the EFI. Any thoughts on this before I go on a sensor replacing binge. I'm thinking about taking it to a Toyota tech for diagnosis because If I just start replacing sensors it could get really expensive, and the ECU and EFI stuff is a little over my head. Any thoughts? Thanks
Old Jan 29, 2008 | 09:52 AM
Georgiadave's Avatar
These engine codes are a bit obtuse. It looks to me like code 51 is telling you that your throttle position sensor is malfunctioning. That would be consistent with lack of power. I would check to see if the wiring is properly connected to the TPS. There are some threads on TPS on this site that should give you more insight into TPS troubleshooting.
Old Jan 29, 2008 | 03:01 PM
runslikecrap's Avatar
check your fuel filter. i know its a pain but i was experiencing similar problems and found my ff to be like 80% clogged.
Old Jan 29, 2008 | 03:48 PM
js9924's Avatar
Originally Posted by WTAllstar
SWITCH SIGNALS
--A/C AMPLIFIER
--TPS/CIRCUIT
--ECU
that is correct for that code but dont waste your money replacing stuff that may work fine go get a cheap multimeter they are $20 and check the sensors according to the service manual. also check the wires too cause they need to be in good shape or the sensor is irrelevant as the info never makes it back to the ecm.
Old Feb 27, 2008 | 12:49 PM
de6w6it's Avatar
I have the same code, I have already replaced my tps, and with old one, without one, and with new one, same symptoms, and same trouble code, 51, lemme know what you find, i will do the same
Old Feb 16, 2022 | 04:56 PM
ImJustSaiyan's Avatar
Well 14 years later and I’m having the same issue. New OEM TPS from 22re performance and it didn’t fix it. Did you ever find the root of your issue? The pigtail is brand new as well. I soldered it on last year. Idles like crap a couple minutes after start up and back fires through intake before dying when I give it as sudden surge of throttle.
Colington
Mar 8, 2020 09:51 AM
steve miller
Oct 10, 2015 01:40 AM
smiley52
Jul 11, 2015 05:16 AM
Roger Borba II
Jul 9, 2015 05:05 PM
Jnkml
Jul 6, 2015 01:20 PM
