Engine 3vz 3.0 missfire, Hesitate and surge at RPM < 3000
Old Mar 4, 2022 | 03:52 AM
3vz92's Avatar
hello,
i got recently a Hilux 92 with 3vz engine 3.0 L. the problem i am facing is that when I start the engine and run few Miles everything looks normal. after a while ( 3-5min) i feel a hesitation which disappear when i turn off and on the engine. it will reappear again once i drive back 3-5 min.
another thing to highlight, when my rpm is below 3000 , i feel lack of power. as soon as i reach 3000 /3500 rpm i feel a sudden change in the performance and a huge power in the P/u which is exactly its original perfromance.
I changed my fuel pump, air filter, distributor cap, AFM, checked my timing belt , o2 sensor....
I still have couple of things to do:
- cleaning Fuel Injectors
- Check the Fuel pressure Regulator
- TPS sensor
please advise if this happened before with you in order not to waste more money and time.
much appreciated
3vz92
Mar 17, 2022 11:33 AM
Miner man
Jan 1, 2021 08:47 AM
spainobain1234
Nov 29, 2018 06:14 PM
LIVES4CRAWLIN91
Nov 21, 2010 11:14 PM
Shock5
Feb 22, 2010 12:40 PM
