Educated opinions? Timing chain/noise related
Old Oct 12, 2011 | 07:15 AM
carter_SR5's Avatar
So my 22re started making a horrific noise on the way to work and initially thought - timing chain issue, as it is quite common.
Upon taking the valve cover off I inspected the guides and found the driver side looks to be metal. Thus, someone has been in here already and with 208k MILES on the truck I don't find this too hard to believe, the previous owner must have been a keener and replaced it properly.
Can anyone with a trained eye confirm that this is what they are supposed to look like?
Here's the driver side:
Here is the passenger side:
And a video of the noise. After listening to it more I think it maybe a bearing in one of the pulley's. I DID replace the alternator last week when battery and park brake light came on and wasn't charging at all.
(click pic)
Old Oct 12, 2011 | 07:27 AM
irab88's Avatar
loks like it. here is a link to my re-build thread, you might be able to compare my pics to what yours looks like:
https://www.yotatech.com/forums/f116...d-pics-232381/
(i also notice you have a 22r-ec)
Old Oct 12, 2011 | 07:41 AM
SCToy's Avatar
Leaking exhaust near the manifold can sound like a rattling chain, so check that while you're at it. Ask me how I know haha
Old Oct 12, 2011 | 02:45 PM
carter_SR5's Avatar
Found the cause lol.
Water pump/Belt ended up being the cause. Mainly the belt. I have never heard a belt like that before, for about 10 minutes I was convinced I could hear a knock. Fixed for under $30 - this is why I love these trucks.
Old Oct 14, 2011 | 03:54 PM
JShaffer0525's Avatar
could you be more specific? i believe i just developed the same noise and im not ready to tear into the timing chain yet.
Old Oct 14, 2011 | 05:30 PM
carter_SR5's Avatar
What specific's are you after? The belt had got oil soaked from a valve cover leak and it stretched to the point where sliding the alternator all the way over to tension the belt wouldn't keep it tight enough. New belt fixed that. Water pump also felt like it was grinding when I spun it by hand without the belt on.
Old Oct 15, 2011 | 01:31 PM
thats what i was looking for, thanks.
Old Oct 15, 2011 | 02:51 PM
xxxtreme22r's Avatar
your timing chain guide is also busted, see the mark it's making in the cover? It's only a matter of time, I would change it and clean out the oil pan of what's left of that guide.
I'll see if I could get a pic of what the top of that guide should look like.
EDIT: Here ya go.
Old Oct 15, 2011 | 03:01 PM
Edit dang it, you said that side is a metal guide already? If so disregard. lol
icentropy
Sep 16, 2020 02:47 PM
A2theK
Jul 12, 2015 10:46 AM
smiley52
Jul 11, 2015 05:16 AM
zd92655
Jul 5, 2015 04:25 PM
