Early and late 22R oil pans swap?
Old Nov 30, 2009 | 02:26 PM
annoyingrob's Avatar
I spun a bearing on my 86 22R-TE, and have access to an early model 22R-E out of an 83 Celica to swap in as a replacement. Obviously, I'll need to swap oil pans. Do they interchange between the two?
Old Nov 30, 2009 | 02:48 PM
camo31_10.50's Avatar
i'm pretty sure they do???..all the blocks were exactly the same...i wouldn't see why not
Old Nov 30, 2009 | 03:06 PM
abecedarian's Avatar
As far as I know, the pans should swap. Just make sure you change the oil pick-up tube from yours to the Celica's too.
Now, on the other hand, if you're keeping the turbo, you'll find the blocks are different enough (oil return from the turbo), not to mention the compression ratio, etc. that is unique to the turbo'd engine, that it's not that simple of a swap. The heads are different- intake and exhaust are different port shapes, etc.
Old Dec 1, 2009 | 12:48 PM
jimep's Avatar
Will the oil pan clear the crossmember and sway bar? I'd chek measurements first. I have never dealt w/ celica oil pans but the old sfa truck oil pans won't fit and 2 wd oil pans will not fit in 4wd's. Or is it the other way around? if u strait axle it u can run whatever u want.
Old Dec 4, 2009 | 10:14 AM
The early and late blocks aren't exactly the same. There are differences in deck height, and a few other small changes. I wasn't sure if the oil pan was different.
It's a moot point right now, I'm holding off for a later model 22R motor.
icentropy
Sep 16, 2020 02:47 PM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
Sep 4, 2015 09:27 AM
87blyota
Jul 10, 2015 04:31 AM
