Drive shaft
Old Aug 11, 2020 | 06:31 PM
Spread5150's Avatar
5 Year Member
Drive shaft
I have come to the drive shaft in my list of things to do. While getting some stuff done i had the carrier bearing replaced. Mine was pretty tired and it needed to be done.
Which leads me to my U joints. In my 94 extended cab 4x4 v6 how many do I have ? Looks like three to me but maybe I don’t have that right. I figure it’s time to do them. Based on everything else on the truck I have replaced I imagine these are the original 25 year old parts and everything along the drive shaft is looking pretty tired. Are all three ( if that’s how many I have ) the same size ? While messing with this drive shaft is there anything else I should be checking for ... it looks like there is a second carrier bearing in there but I could definitely be wrong.
Old Aug 12, 2020 | 08:02 AM
rattlewagon's Avatar
Just add grease. Dont fix if they're not broken.
If you have a 2 piece shaft, there are 2 in the cardan joint (these are kinda a pita to change) , one at the t case and one at the diff. So should be 4 total. I believe the ones in the cardan joint are different than the ones in a single joint.
While you probably dont need to ad more clearance, this is a good visual of braking them down.
http://www.4x4wire.com/toyota/tech/cvmod/
Old Aug 12, 2020 | 04:58 PM
scope103's Avatar
Just add grease. Dont fix if they're not broken ....
You should at least slide under there, grab the prop shaft, and try to rotate it. Does it move just a little bit, but feel pretty firm? Shoot some grease in there and you're good. Does it rock back forth 15° with a clunking sound? Can you see relative movement in the u-joints? Replace 'em all. http://web.archive.org/web/201204171.../3propelle.pdf RockAuto has joint kits for not much money.
jake_v
Aug 27, 2015 08:53 AM
Polaris2012
Mar 12, 2014 06:54 PM
94exblack
Mar 18, 2009 08:51 AM
neil_P_smith
Jan 16, 2005 03:23 PM
