Door Hinge quick question!
Old Jun 18, 2012 | 05:20 PM
ktm250exc250's Avatar
For my '87 pickup is the drivers side bottom hinge compatible with the passenger upper and lower side? The driver's lower is all that i can find out there! I need both the passenger side upper and lower hinges.
-Thanks
-Will
Old Jun 18, 2012 | 11:18 PM
wyoming9's Avatar
Wink
It looks like the hinges are the same .
I have a set of the drivers side ones but after looking for 20 minutes they must be hiding with all the 10mm 12mm and 14mm wrenches and sockets that become invisible when looking for them.
Without having one off it is hard to tell
Old Jun 19, 2012 | 12:43 PM
arlindsay1992's Avatar
There are two different types of hinges. The factory ones are stamped with "1" and "2." The ones stamped "1" can be swapped with each other and the ones stamped "2" can be swapped. I don't remember which stamp goes to which location. You should be able to find the stamp just by opening the door.
jasonty
41
Dec 23, 2018 01:00 PM
shisha1999
Sep 20, 2015 11:44 AM
icentropy
Jul 14, 2015 10:23 AM
Cplmike
Jul 8, 2015 08:47 PM
