Does anybody apply some kind of hi-temp sealant to exhaust gaskets?
Old Oct 16, 2014 | 02:41 PM
Qbert's Avatar
92 4Runner 4X4
3.0 VZE
5 Spd
Just wondering has anyone used any kind of sealant to their exhaust manifold gaskets?
Old Oct 16, 2014 | 03:13 PM
oldblue's Avatar
are you talking about the collector or where the manifold bolts to the head? you shouldnt need any sealer in addition to your gaskets. from what i've seen, the sealer usually makes things worse.
Old Oct 16, 2014 | 03:15 PM
Qbert's Avatar
I'm talking about the ones from the manifold to the heads.
Old Oct 16, 2014 | 06:38 PM
nv4runner's Avatar
I've done my head gaskets a couple times and only used the stock exhaust gaskets without sealer. Only exhaust leaks I've had since then were at the collector to pipe connection, and tightening the bolts took care of that.
If you take care of exhaust leaks soon after discovering them you save the parts from getting damaged and not sealing again.
Old Oct 16, 2014 | 07:39 PM
Old_ blue's Avatar
Oem gaskets seal pretty well make sure you torque in sequence. inner and torquing your way outward. The only high temp rtv that could be usefull is on the air injection tube on top the manifold
Old Oct 17, 2014 | 02:17 AM
Qbert's Avatar
Thank you for your advice.
Old Oct 18, 2014 | 02:09 AM
wyoming9's Avatar
Red face
I still every once in a while use Permatex #2 on things like where the flanges join at the cat .
This is to help hold things in place till I get the bolts in.
I also used it way back when on the header gaskets on my small block Chevy.
kgcwb44
Jan 29, 2023 10:02 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Dakotaneu
Jul 27, 2015 12:03 AM
Coreyr384
Jul 10, 2015 11:13 AM
