Do I have a Welded Diff?
Old Nov 3, 2008 | 11:19 AM
elripster's Avatar
Originally Posted by Whiplash Willy
Thanks for all of the good info guys.
I am used to driving RWD cars, and have driven one with a welded diff, which is what the chirping reminded me of during slow turns. This is my first 4x4 truck, and I was just trying out the 4H/4L to see how/if it worked. I am glad I asked, because now I know to not drive around in 4wd on pavement! I am going to check if the front is locked or not like you guys said, but from looking at the rest of the truck, I doubt the previous owners did any modifications to it.
Assuming the truck has open diffs on the front and rear, if I lose traction in 4wd, is the front and rear wheel that looses traction going to just spin as all of the power will go to the wheels with no traction? I am wondering if I should take this truck out this year when it snows, or not.
Does anyone know of any good resources where I can get more information on how this 4wd system works?
Howstuffworks is fine. This is a very simple 4WD system. Even those with the auto hubs or ADD flanges essentially work the same way.
Auto hubs, like manual hubs lock the front wheels to the front axles. Auto hubs are failure prone and were not common. If you have them it's not a bad idea to swap to manual hubs. When you shift the transfer case in to 4WD it simply engages the front drive shaft. Now the front and rear drive shafts spin together and this is why you should not drive on dry pavement. Snowy pavement is another story, 4WD is fine.
The ADD system has flanges that lock the front wheels to the axles all of the time. However, there is this little sleeve that disconnects the d-side axle from the differential internally when in 2wd. The shifter again just engages the front driveshaft. When in 2wd, the halfshafts spin bu the driveshaft and ring gear to not.
The ADD system can be shifted on the fly. The manual hub system can be too as long as the hubs are engaged. They auto hub version cannot be shifted on the fly if I remember correctly. You can shift on the fly at most any speed as long as you aren't spinning the rear tires.
You need to stop to switch into 4LO. I have been told my auto can shift into 4LO on the fly but I haven't tried yet.
Frank
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
Badlander
Oct 10, 2015 08:05 PM
Odin
Sep 26, 2015 06:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
