DIY Video: 1994 4runner Complete Front Brake w/ New Rotors & Wheel Bearings
Old Oct 25, 2010 | 07:53 AM
ByThaBay's Avatar
DIY Video: 1994 4runner Complete Front Brake Job w/ New Rotors & Wheel Bearings
Just submitted to the staging area, but here it is anyways:
http://eturkov.blogspot.com/2010/10/...ner-front.html
Old Oct 25, 2010 | 07:22 PM
hgill's Avatar
Thumbs up Thanks!
Thanks for sharing the video
... its just in time ... i have been debating on replacing my rotors n brakepads on my pickup ... just couldn't decide if I should do it myself or leave it to the mechanic ... The video is pretty detailed and i think im ready to jump in soon once I decide on the parts and tools required ... Im leaning towards Hawk breakpads n brembo rotors .. which brand parts did you go for?
Old Oct 25, 2010 | 08:15 PM
ByThaBay's Avatar
Initially I went for centric semi-metallic pads, but the performance was terrible. I switched back to OEM compound and I couldn't be happier. The rotors are fantastic (the ones you see in the video). They are r1concepts premium slotted rotors. With the OEM pads you're going to want to apply some grease between the shims.
Old Oct 26, 2010 | 04:28 AM
TNRabbit's Avatar
That was great. Thanks for taking the time to make it. That will surely help a lot of newbs~
I bought the Hawk HD pads & while a little noisy/dusty, they ROCK for stopping! I also bought dimpled/slotted rotors from RotorPros.com. They treat me right a few years ago on Ford Expedition rotos & I went back to them for my new ones. I've been through only one set of Toyota rotors in the past 160,000 miles...thought I'd give these a try this time around
Old Oct 26, 2010 | 03:55 PM
iamsuperbleeder's Avatar
maybe I'm missing something, but why did he bother to take the steering arm off
good videos though!
Old Oct 26, 2010 | 03:59 PM
xxxtreme22r's Avatar
my guess it's easier to access the caliper bolts by turning the rotor? didn't watch the whole thing though. good job nonetheless.
Old Oct 26, 2010 | 04:01 PM
rustypigeon's Avatar
good videos though!
I think that was so he didn't have to disconnect the brake line to remove the caliper.
I generally remove the brake line, but that is always a pain because I need to find someone to push the pedal so I can bleed my brakes.
Old Oct 26, 2010 | 04:12 PM
snobdds's Avatar
yea very good job. Great detail!
Old Oct 26, 2010 | 04:20 PM
oh, and so many useless specialty tools used in these videos
Old Oct 26, 2010 | 04:24 PM
I did mine without removing the brake line nor the steering arm.
I gotta watch the whole thing, I wanna see if he lubed the spindle bushing while he was in there. lol.
Old Oct 26, 2010 | 04:36 PM
nope
Old Oct 26, 2010 | 06:26 PM
TNRabbit's Avatar
Get one of these & you won't have that problem:
Old Oct 26, 2010 | 06:59 PM
How did you do that?
Old Oct 26, 2010 | 07:02 PM
unclipped the line from the upper control arm and slid the caliper aside, held it in place with a bungie.
Old Oct 26, 2010 | 07:21 PM
hmm. You must have a different setup than mine. On my '94 PU, the line is secured 360 degrees by a bracket. The bracket is held to the steering knuckle by a steering knuckle bolt.
The only way I can swing the caliper out of the way is to remove the hard line from the caliper, or remove the bracket bolt that goes into the steering knuckle.
Old Oct 26, 2010 | 07:23 PM
i would just remove the bracket bolt then.
Peevedkitten
11
Aug 31, 2015 06:57 PM
ojm3
Aug 28, 2015 12:26 PM
Phessor
Aug 25, 2015 04:53 PM
trailgoat
Aug 13, 2015 05:54 PM
coffey50
Jul 28, 2015 10:55 AM
