Distributors known for going bad?
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Pretty sure every 20, 22R, RE and RET cam is the same...
pretty sure... I go check now...
well, pecker-wood Chilton's doesn't even list the RET in their manual... :-/
Ya, I got a Haynes and it has JUST enough info to keep me from throwing it out in disgust, ie torque patterns and values.
He mentions a 261 cam, I put the smallest Comp- 252 in mine I wanted to update the cam- Comp hasn't updated to 22re specs because it's ground for the 22r, - I'm not saying anything bigger won't work but I had a bad experiance with another vehicle where the MAP/ecm did NOT like the cam and I didn't have any tuning capabilty to compensate- lots of power but the idle was crap.
nonstop
7
Aug 11, 2015 09:26 AM
Flossy
Aug 5, 2015 05:14 PM
