Distributor making new hissing sound
Old Jan 23, 2011 | 02:50 PM
Sansocal's Avatar
I was out messin around on some logging roads and my truck started making a hissing noise, it sounds like a air leak or something, but i think it might be the distributor. I had just changed oils to 20w-50. Has anybody else had this problem?
Old Jan 23, 2011 | 03:36 PM
ChefYota4x4's Avatar
Not sure if you have either of the VSV's in your system, but my 22re made that mysterious hissing sound in two cases... Both times, I had reversed the vacuum lines for the A/C vsv or the Steering Idle Up Vacuum Valve.
Far as the Dizzy... not sure on a hissing sound.... other than the bearings going out, possibly could make a hissing sound(similar to hissing). I would take my stethoscope and try to listen at all points of the dizzy.... see if it's coming from in there.
Best of luck,
Mark
Old Jan 23, 2011 | 06:54 PM
Sansocal's Avatar
I haven't been messing with the vsv lately, (theres one for the charcoal canister on this) ill check that next time i have the hood up. I was so close to having this thing noise free... could switching to 20w-50 oil starve the dizzy bearings?
Old Jan 23, 2011 | 10:49 PM
Not sure, but pretty much every Toyota Motor Guru I've spoken with told me to go with 10w-40. I'm running a brand new motor, but ....anyway, I can't be sure on that one, Sansocal. Maybe it's just coincidence in the timing of things?
Old Jan 24, 2011 | 07:47 PM
Sansocal's Avatar
I think i'm just gonna seafoam the crap out of it this weekend, and an oil change back to 10w-40... if that doesn't do anything then i guess ill be looking at a new distributor later on.
Speaking of distributors, what does the "air gap" do? I know there are specs that say it should be .2-.5 mm feeler gauge. I could fit a .53 mm in there.
haha, i'm just looking for a problem in this car as I get 11-12 mpg.
Old Jan 25, 2011 | 12:08 AM
Take a stethoscope to it and make SURE it's the dizzy, San.... And like I said, ....I can't say that's the wrong oil for ya, was only sharing what I've been told by a few Yota guys, including the Foreman of my Local Dealer(I know him, personally, ....funny thing is, they don't carry 10W-40 there, hahaha.)
Hope you get it narrowed down before throwing parts at it. You're sure your dizzy is, well, unhappy? lol. It's not possibly the Oil Pump or a pulley making the noise? My Idler Pulley in my 22re was making a heck of a racket once.....then, my water pump made a nearly identical noise. Just sayin...
Old Jan 26, 2011 | 11:49 AM
TNRabbit's Avatar
I used 20w-50 for over 100,000 miles with no issues.
however, check out www.bobistheoilguy.com to find out EVERYTHING you've ever thought about, wondered, pondered, ANYTHING about oil & engines. Also might appear under www.theoildrop.com
Hissing noise......sounds like a vacuum leak. Use an UNLIT MAPP or propane gas torch to check for vacuume leaks; when it idles up, you have a leak there. (@200 rpms)
10 or even 0W-40 synthetic is supposedly the way to go. Thin to protect at startup, 40 weight at temp to protect.
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Feb 17, 2017 07:11 AM
msane99
Jul 11, 2015 08:08 PM
