Disabling ABS
Old Apr 17, 2006 | 09:37 PM
jsnby's Avatar
Disabling ABS
My 92 runner has the rear wheel abs. The sensor is shot so the ABS light in the cluster is on.
I'm going SAS and got a deal on a 4cyl 3rd with 5.29's and a detroit for the rear of my truck, so i need to be able to disable the ABS permanently since the 4cyl 3rd doesn't have the opening for the sensor. I need to be able to turn off the dash light and do it in such a way as to pass CA smog check deal.
unplugging the light bulb in the dash won't work.
UKMeyers said that he removed the sensor from the 3rd and just tied it up out of the way and it worked okay. Anybody else do this?
Any other ideas on how to get this to work safely?
Old Apr 17, 2006 | 10:28 PM
Turd Ferguson's Avatar
A resistor matched to the signal the unit sends crimped onto the wire should do the trick i think....
Old Apr 18, 2006 | 12:14 AM
jsnby's Avatar
any idea what that resistance is or what wattage resistor(1/4 watt, 1/2 watt) to use?
Old Apr 18, 2006 | 01:42 PM
Elvota's Avatar
I tied my sensor out of the way as well. No light. No brake problems... unless you consider no ABS a problem.
Old Apr 18, 2006 | 01:48 PM
MossyRocks's Avatar
I unplugged (ripped the wiring harness out) the ABS on my 3rd gen 2 years ago and it solved all my problems
Old Apr 18, 2006 | 07:02 PM
jsnby's Avatar
cool...i think that's what i'm going to do.
anybody know how much the sensors run from a junkyard? The stealership quoted me $150.
JimiJams
Sep 28, 2015 06:14 PM
JamesDINAN
Sep 22, 2015 05:37 AM
BimmerSage
Sep 17, 2015 11:48 PM
matt1833
Sep 16, 2015 07:11 AM
zz_denis
Sep 6, 2015 03:43 PM
