diagnose my head gasket plz
Old Feb 15, 2016 | 01:39 PM
ethanethan's Avatar
The symptoms are really piling up here. 93 toyota pickup 22re, I've got--
1) burning coolant,
2) high/surging idle when warming up and
3) oil in coolant.
Could this be an intake manifold gasket problem or 100% head gasket?
Planning to rent a car (or buy a nissan) and fix it in my driveway. Once its above freezing maybe.
thanks for any help.
Old Feb 15, 2016 | 02:37 PM
millball's Avatar
A leak-down test might tell details of exactly where your troubles lie.
If theres oil in the coolant, its very likely the head gasket, or maybe a cracked head.
I don't think there's any way to put oil into the coolant from the intake manifold.
Edit: I guess that it might be possible for a timing cover fault to put oil into the coolant, but it's unlikely.
Old Feb 16, 2016 | 02:21 PM
ethanethan's Avatar
Ok thanks! I'll just take it apart and try and find out. Should not keep driving it, but i have to....
Old Feb 16, 2016 | 06:10 PM
92ehatch's Avatar
Quick non technical test. Top off coolant and start engine with radiator cap off. A blown headgasket sometimes will cause the coolant to shoot out of the radiator from the extra pressure in the system. Works betteron a cold engine. Revving the engine can do this as well but revving to high will throw coolant out as well.
goofybud16
Mar 9, 2017 07:54 AM
abatter24
Dec 27, 2015 03:47 PM
Jota1993
Dec 22, 2015 08:01 AM
Dirks87runner
Dec 21, 2015 02:18 PM
