Defroster related to A/C Compressor?
Old Feb 25, 2012 | 08:28 PM
Sin's Avatar
Sin
When I bought my truck, the A/C system wasn't working - so I'm thinking of removing the compressor, just cause.. But if I remember right, the compressor kicks on when you turn on the defroster? Is that correct?
I don't plan on fixing the a/c for awhile, just thought it might free up some space for starter work later on. Ideas?
Old Feb 25, 2012 | 08:53 PM
justin_4runner's Avatar
yes when its on defrost it will kick on to help pull moister out of the inside, but if u are planning on fixing it at any time i would not pull it out cause air and moister getting into the system and having to replace other items then maybe a pump or where its leaking from that cause it not to work. it will dry out seals and could cause other problems from having the system open(rust)
Old Feb 25, 2012 | 09:17 PM
Sin's Avatar
Sin
Alright thanks, that's the info I needed right there.
Old Feb 25, 2012 | 09:32 PM
James Woods's Avatar
You dont need to worry about rust inside of your A/C system, the A/C system is made up of aluminum which does not rust, the moisture inside of an A/C system mixes with the refrigerant and oils and makes a corrosive acid and sludge that ruins a system.
The A/C does come on with the defrost as stated by Justin to remove the moisture in the air inside your truck, your defrost will still work without A/C, it will just take a little longer. Besides you live in Arizona, who wouldn't want A/C there.
Old Feb 25, 2012 | 10:17 PM
Sin's Avatar
Sin
It'll be fixed eventually, just can't afford it now and YES a/c is a must have in Southern AZ - my daily driver has a/c
Old Feb 26, 2012 | 06:43 AM
Marc's Avatar
The A/C DOES not come on with the defrost unless the A/C button is engaged.
Some vehicles do that but not 2cnd gens.
Old Feb 26, 2012 | 09:57 AM
Sin's Avatar
Sin
kawazx636
Oct 6, 2021 03:03 PM
zytra
Jan 24, 2019 03:16 PM
Badlander
Oct 10, 2015 08:05 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
