Dash board replacement.HELP
Old Mar 22, 2015 | 09:27 AM
barrentine's Avatar
I have a 1989 Toyota 4x4 deluxe pickup.Will a 94 dash board fit this truck?Also I have a tilt steering to go in also.The only problem I see with it is that the tilt steering doesn't have the universal joint type connector.It just has splined shaft.Is there a universal available for this.thanks
Old Mar 22, 2015 | 09:48 AM
thefishguy77's Avatar
I believe the dashes should swap with relative ease. There may be some small differences due to factory options but the trucks are the same size. As far as steer goes. I have absolutely no friggen idea. Good luck hope this helps
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
smilen724
13
Nov 8, 2015 04:11 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
toyotasaurus
Sep 24, 2015 03:30 PM
