Cruise control
Old Jun 26, 2015 | 08:36 AM
Nathan_F's Avatar
Cruise control
I have an 89 Toyota pu. 3.0 4x4 5spd. Looking for advice/recommendations on after market cruise controls.
Old Jun 27, 2015 | 02:19 PM
fdp101452's Avatar
Years ago I bought a cruise control from j c whitney and put it on my 88 Toyota pickup and it worked fine. Might give them a look...........
Old Aug 19, 2015 | 04:03 PM
hyota's Avatar
I have an '88 4Runner, 3.0 5spd. Cruise control deteriorated over the course of a few months. I dismantled the vacuum actuator and discovered that the rubber bellows had itself deteriorated, lots of cracks & leaks.
I bought a Mopar vacuum actuator. I routed out the inside of the Toyota actuator, and mounted the Mopar inside it. Re-installed in the truck, you can hardly tell it's not stock.
The Toyota actuator has 3 wires: vacuum valve, vent valve, ground. Normally vacuum is closed and vent is open. Presumably, when active, the controller closes vent, then controls the vacuum valve to maintain speed. All well and good.
The Mopar actuator has 4 wires: vacuum valve, vent valve, dump valve, ground. I simply tied vent & dump together.
The Toyota is common ground, the Mopar is common 12v (or v.v.). There's a diode in the Mopar that has to be cut or reversed.
Result: not good. When engaged, the controller closes vent and opens vacuum--and keeps it that way. Engaged at 55mph. Accelerates to 60mph. 70mph. I touched the clutch at 75mph to disengage.
Does anybody have the faintest idea why the controller would simply pull the throttle as hard as it can and just leave it that way? Death wish? I can think of no combination of mis-wiring that could result in energizing both valves this way. I'm baffled.
Any veterans here, please feel free to move this to a new thread. I don't have 15 posts, I can't open a new thread.
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
kawazx636
Oct 6, 2021 03:03 PM
kcaudill
Oct 10, 2015 02:39 PM
Shagool22
Sep 28, 2015 07:53 PM
toyotasaurus
Sep 24, 2015 03:30 PM
