Crap! Head Gasket Giving Up the Ghost...
HG job turns into full rebuild...plus full axle service....plus exhaust....plus.....
Well, after all these years bragging about no HG problems, it looks like I finally got bit. I'm going through coolant like crazy (this stuff is more expensive than OIL!), to the tune of about a gallon per couple tanks of gas, and can find no other reasonable explanation. The problem is, I don't have the telltale sweet burning smell from the exhaust. I guess I'll have to break down & get that compression tester I've wanted for years...
Of course this happens at the WORST possible time; this is my only transportation! $h!t...
I have all the tools, knowhow & a place to work; I just need the TIME! Wondering if I should get the head/valves reworked while I have them off. I'l probably replace the timing belt & put a new oil pump on her as well. i dread starting this...
Co-Founder/Administrator
Bummer, sorry to hear that.
Will you rebuild or put in a new block if more damage is done to the block or what?
The reason I did not fix up my 4Runner was because it needed a whole new engine, and with labor installing it, it was 1.2x the blue book value of the rig.
Yours might be a lot easier fix than mine was.
sounds like ur in the same boat i'm in. getting mine checked out on march 5th and hopefully get it back up and running by the end of the week. really hope i didn't ruin anything else and caught this issue early...
Engine swap is a good idea. I did one on my 4x4 and it is sweet. But the head gasket can be replaced for $150-$200 in parts including timing belt. See enginebuilder.com for gaskets and bolts. could be done in 5-8 hours.
[COLOR=Blue]Well, after all these years bragging about no HG problems, it looks like I finally got bit. I'm going through coolant like crazy (this stuff is more expensive than OIL!), to the tune of about a gallon per couple tanks of gas, and can find no other reasonable explanation. The problem is, I don't have the telltale sweet burning smell from the exhaust. I guess I'll have to break down & get that compression tester I've wanted for years...
Might as well and check the Knock sensor and wire while you are in there. I got a the heads machined and valve job for I think $450.
Sorry to hear about it, but start planning something.
Gee TN, sorry to hear about. If I lived anywhere near, I'd help you do the job just because you've been so helpful when I needed it. I guess lets find out if it's indeed the headgasket, first.
I did my headgasket 3 months and 2k miles ago, I just got new bolts, timing belt water pump and did the valve seals. I didn't send the heads out and so far so good. We'll see how long it lasts though. I've 158k on a 95 3.0
While I've got the truck down, I've been needing to rebuild a sticking caliper. Has anyone purchased these from Marlincrawler?
http://www.marlincrawler.com/htm/brakes/calipers.htm#
I could buy the rebuild kits and pads from the dealer and almost spend the same amount. Combined with MC reputation...how can I go wrong?
__________________
__________________
