Crack in Timing Cover
Old Jun 22, 2006 | 08:31 AM
zredtruck's Avatar
OK, I'm going to replace the timing chain and components in my 22R (see 22R sounds like diesel). How do I avoid the crack just below the head bolt in the timing cover?
Old Jun 22, 2006 | 08:38 AM
EWAYota's Avatar
I Dont Know! TRY USING A SMALLER FONT!
Old Jun 22, 2006 | 10:26 AM
surf4runner's Avatar
crackhead
Old Jun 22, 2006 | 10:36 AM
TNRabbit's Avatar
Start by not making direct eye contact with it...
Old Jun 22, 2006 | 10:39 AM
zredtruck's Avatar
ok funny, I had no idea the font was going to be that big. Any of web wackers got an answer to the question at hand?
Old Jun 22, 2006 | 11:04 AM
maxpower_hd's Avatar
You should be OK as long as you get ALL of the bolts out of the cover. There is one under the distriubutor gear that you can't really see unless you remove the distributor and clear out the oil that settles there.
I'm assumuing that is the one you are referring to. Also loosen or remove the oil pan bolts. Then just be very careful. You could always remove the head completely but that kinda sucks unless you're doing a rebuild anyway.
Good luck.
Old Jun 22, 2006 | 11:12 AM
zredtruck's Avatar
when i got the engine in question its timing cover had a crack from the bolt under the distributor gear. when i swaped that engine into new body I used another timing cover. that cover produced an identical smiley face crack just under the cast knob, on the timing cover, that the bolt under the distributor gear sets into?
Any ideas? Does anyone know what the torque spec is on that bolt?
A2theK
Jul 12, 2015 10:46 AM
smiley52
Jul 11, 2015 05:16 AM
icentropy
Jul 9, 2015 02:12 PM
