Coolant leak behind engine?
Old Nov 13, 2014 | 03:12 PM
BeefSupreme's Avatar
I've narrowed a leak I believe I get when running the heater down to the upper of these two hoses (by the exhaust blockoff and covered in grime.)
Do you guys know which part that is and if it's a common problem?
I can't seem to find a schematic of the cooling/heating systems
Thanks yall
Old Nov 13, 2014 | 04:21 PM
Yota4Runner86's Avatar
It's a plate that just bolts to the back of the head. It is a slightly common problem. They usually never give a problem unless it's rusted through. Or someone has had it off before and instead of using the proper gaskets they just silicone it and that doesn't seam to last on these plates.
Old Nov 13, 2014 | 05:49 PM
Do you know the name or part number? I think it's fair to estimate that it's rust... so far I've had my brake line and spring hanger rust through
Old Nov 14, 2014 | 05:11 AM
ouch! I would hate to be ridding along when either of those fail. No I don't know the part number.
Old Nov 16, 2014 | 07:35 PM
Luckily I was bleeding the brakes when the line burst... and the spring hanger is just sitting comfortably inside the frame. I'll get to it eventually
Colington
Mar 8, 2020 09:51 AM
Eggslinger
Jun 8, 2019 03:32 PM
andrewtexas123
Jul 14, 2015 04:29 AM
jakebarrett
Jul 10, 2015 07:15 PM
Avenged
Jul 9, 2015 07:55 AM
