Code 27
Old Jul 24, 2009 | 07:38 PM
SeanDev's Avatar
Code 27
So i finally got the HG repair all sewn up and went to start it, wouldn't start, would maybe stumble for a few repetitions, then die.
Its throwing a code 27.
Sub Heated Oxygen Sensor Signal?
Anyone have any idea what's causing this?
Old Jul 24, 2009 | 07:40 PM
BoostinChick's Avatar
Bad front O2 sensor....
You can test it with a voltmeter.
Old Jul 24, 2009 | 07:42 PM
SeanDev's Avatar
Yeah? OH .
They're both plugged in and both functional. Switched them with another 95 4runner that I just replaced crank bearings on and got running like a week ago.
Sooo any ideas as to why they might be throwing a code?
SeanDev's Avatar
/ which one specifically
Old Jul 24, 2009 | 07:43 PM
Did you replace the front with a new O2 sensor? Did you test the O2 sensors that you threw in to verify they are functioning correctly? If you are sure the O2's are in good standing test the ECM/ECU.
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
