code 21 on 22re
Old Aug 2, 2013 | 05:17 PM
BigHoss_27's Avatar
code 21 on 22re
Truck throws a code 21 and does that have any effect on the way my 91 4x4 pickup runs
Old Aug 2, 2013 | 06:40 PM
brianh699's Avatar
Code 21 is for your oxygen sensor, it may not effect your running but I bet it's impacting mpg. If your wiring is good the oxygen sensor is probably bad.
Old Aug 2, 2013 | 06:49 PM
BigHoss_27's Avatar
PO did a lil hacking to harness but I got a used harness and just confused on best way to go about putting it on
Old Aug 2, 2013 | 08:22 PM
brianh699's Avatar
You have a full engine/ecu harness? I would get in there with a voltmeter and check connections before replacing the full harness. You may have a bad sensor, no point in replacing wiring if that's the case.What engine do you have? Oxygen sensor testing is pretty straight forward.
Old Aug 2, 2013 | 08:31 PM
BigHoss_27's Avatar
Harness has to be replaced the po spliced wires for some reason to make the master power switch a flip switch in truck you have to flip that then you can crank it with the key. But how do you test it that way I know it its bad and isn't there 2. O2 sensors
Old Aug 2, 2013 | 08:49 PM
brianh699's Avatar
This is the procedure for testing.This is from a 93 fsm your specs should be the same. You didn't specify engine so I'll post both. 22re http://personal.utulsa.edu/~nathan-b...42oxygense.pdf 3vze http://personal.utulsa.edu/~nathan-b...01heatedox.pdf
Old Aug 2, 2013 | 09:03 PM
BigHoss_27's Avatar
I have ohm meter but anything to do with electrical I suck so I'm a little confuse on still how to do it
Old Aug 2, 2013 | 09:08 PM
BigHoss_27's Avatar
Like what setting do I put ohm meter on and the 2nd page of what link you posted confused me but I have the 22re
Old Aug 2, 2013 | 09:46 PM
brianh699's Avatar
You want to set your meter to check for resistance (The symbol looks similar to a horseshoe). You first want to check how many times the meter deflects in a ten second period. Needle type meters are best for this but it can be done with a digital meter as well. If if deflects more than 6 times in the ten second period it's normal and the sensor is good. If not you continue to page 2 and disconnect the pcv hose and check the voltage across the specified terminals. I wouldn't worry too much about that portion. You want to focus on the first page, and how many times it fluctuates in the ten second period.
Old Aug 2, 2013 | 10:06 PM
BigHoss_27's Avatar
If I get time I'm going to do this tomorrow and if I run into trouble I'll post back so you could maybe help me out
Old Aug 3, 2013 | 08:22 AM
BigHoss_27's Avatar
Where exactly is o2 sensor
Old Aug 3, 2013 | 05:46 PM
brianh699's Avatar
Just in front of catalytic convertor if you look under the truck near the drivers door you will see it in the exhaust pipe.
montanatruck
Feb 26, 2017 07:07 AM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
Jul 24, 2015 06:29 PM
jake_v
Jul 22, 2015 03:17 PM
