Code 12 Help please
Code 12 Help please
Getting a Code 12 Knock Control Sensor signal. Wants to start but won't.
Now I know that's not the code I get for a bad knock sensor, Code 52 or 53...What is it? And what do I need to check to fix it? Thanks again in advance guys!
PS got the code answer from here:
http://www.troublecodes.net/Toyota/
Then found another one that says:
RPM SIGNAL-NO SIGNAL TO ECU FROM DISTRIBUTOR ("Ne" OR "G") AFTER ENGINE HAS BEEN CRANKED
--DISTRIBUTOR/CIRCUIT
--STARTERSIGNAL CIRCUIT
--IGNITER/IGNITER CIRCUIT
--ECU
http://www.off-road.com/toyota/tech/codes/index.html
For code 12. Now I'm confused. 3VZE motor on a '91. Motor cranks and wants to start.
--ECU
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
