Clutch problems
Old Jun 6, 2014 | 05:14 AM
Crazy_Guy97's Avatar
Clutch problems
1986 toyota 4x4 problems. Heres the problem when i press the clutch down and let off it releases at floor. I took off the slave cylinder it was good I going to try bleeding the line. The clutch is almost new
Old Jul 13, 2014 | 08:13 AM
KingsShadow's Avatar
New throw out bearing? Make sure that was installed correctly, if you did the repair or a shop. If it was the shop that did it, I would take it back to them. But good start on the diagnosis. If bleeding the line doesnt help, you might ned to replace the clutch slave and then bleed it.
Old Jul 13, 2014 | 03:25 PM
Terrys87's Avatar
Is it a parts store brand? I have had problems of them not having the correct length of push rod in the slave cylinder. Compare it to your old one.
Old Jul 13, 2014 | 03:48 PM
Teuf's Avatar
As was said, sounds like a pushrod adjustment issue . I had to adjust my pushrod in to the max to work as I like.
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
