Clutch problem????
Old Feb 12, 2008 | 06:37 PM
turboyota1's Avatar
Clutch problem????
I installed daul 23 spline transfercased behind my r151 tranny. While doing this I lost clutch fluid and someone pumped it up. I filled the res. back up and bled it a couple times but when the clutch is pushed in the vehicle still creeps forward until i hit the brakes or put it in neutral. Any idea what this problem is? Could the clutch need bled more? Also when i am in low range 4 low, when i let off the gas the truck comes to a quick stop like something is dragging. I have all new bearings in the front, but i dont think i have any brakes dragging? Could there be something wrong with the daul cases or is it a fresh bearing, brake problem? Thanks for the help.
Derek
Old Feb 12, 2008 | 06:55 PM
rowdy235's Avatar
sounds like its not disengaging all the way. Bleed it a few more times and if it persists it may need to be adjusted at the pedal.
As for the 4 low thing, that commonly happens if the axle ratios are different, are you sure you're getting the same front drive as back drive?
Hope this helps
the1998sr5
15
Jul 14, 2020 08:35 PM
PlayAwhile
Jul 20, 2015 11:36 AM
1996Taco
Jul 20, 2015 12:02 AM
the1998sr5
Jul 16, 2015 06:20 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
