Clutch Pedal master slave pin hole out of round
Old May 9, 2009 | 09:22 AM
dem0nk1d's Avatar
so i've been having issues with shifting and what not. so i went a head and took out the clutch pedal all together so i could inspect the infamous clutch bracket issue. everything looks fine no signs of fractures, but i have notice that the little hole that connects the clutch pedal to the clutch master cylinder is out of round. I heard you can just weld a washer over the out of round hole as a fix. Has anyone done this? i've searched. i will post pictures later.
clutch pedal out of round not the clevis.
Old May 9, 2009 | 09:24 AM
abecedarian's Avatar
Which part is worn- the pedal or the clevis?
Old May 9, 2009 | 09:49 AM
dem0nk1d's Avatar
the pedal is out of round
Old May 9, 2009 | 09:51 AM
given that, I'd weld the hole up and redrill it instead of relying on a couple of washers.
Welds are usually stronger than the surrounding metal though, so be careful.
But if there was a wrecking yard close, I might just go buy another pedal.
Old May 9, 2009 | 10:10 AM
dem0nk1d's Avatar
i was thinking of drilling a new hole just a tad bit higher than the out of round hole. but welding it up sounds pretty good.
Old May 9, 2009 | 03:47 PM
dem0nk1d's Avatar
so i decided to take the advice and took it down to my local muffler man. he welded the old hole shut, and re-drilled a new hole the same size as the clevis pin. everything is back in and working fine. a+ for 30.00 bucks
toyota wanted 76 bucks for a new pedal.
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
wolfpackfan33
Aug 2, 2015 03:36 PM
TJWilly
Jul 31, 2015 02:05 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
