Clutch bracket?? What is this and would this prohibit me from getting in to gears?
Old Feb 22, 2009 | 02:00 PM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
I read another thread relating to checking the clutch bracket, where is this and could this be causing my tranny to not being able to go through the gears once the truck is started? I can get the trans to shift when off, but not when started. Did new slave and master and have been bleeding all day.
Old Feb 22, 2009 | 02:29 PM
jason191918's Avatar
My only guess would be that they are referring to the metal piece that comes in contact with the piston of the slave cylinder.
Old Feb 22, 2009 | 02:35 PM
scuba's Avatar
I believe the clutch bracket is just a piece of metal that reinforces the firewall where the clutch pedal is.
Old Feb 22, 2009 | 02:54 PM
abecedarian's Avatar
... and the piece of metal the slave cylinder acts upon would be the 'release fork' or 'release arm' or 'release lever'.
You did bench bleed the clutch master when you replaced it, correct?
Old Feb 22, 2009 | 02:59 PM
scuba's Avatar
probably not, If not, then that little bubble of air has to go allll the way through...ask me how I know...
Old Feb 22, 2009 | 03:08 PM
You like bubbles?
Old Feb 22, 2009 | 03:18 PM
His name is scuba.
Old Feb 22, 2009 | 03:21 PM
scuba's Avatar
lolz, no because after I replaced both of said parts my crap wasnt working, took like 3 hours of bleeding...
Old Feb 22, 2009 | 03:28 PM
parkkicks's Avatar
i had a similar probelm with getting into gear. turns out my pressure plate was cracked. had to buy an all new clutch.
Old Feb 22, 2009 | 04:58 PM
This is what it is looking like. I didn not bench bleed the master, after pumping the until I legs like Schwarzenegger, I just let it gravity bleed. We got the lines right, I am thinking I have the same pressure plate problem.
Abe, I will be staying at the mason hotel you were at, so that I can still get to work, to bad company isnt paying for it.
Old Feb 22, 2009 | 05:25 PM
parkkicks's Avatar
aww man sorry its lookin like what i had i went with the marlin super hd clutch for my 87 22r 4x4. they ship fast (at least to here) it was 220 after shipping. the thing that hurts is the labor
Dieselmann
Feb 19, 2019 02:57 AM
mskalmus
May 28, 2017 07:51 AM
coffey50
Jul 28, 2015 10:55 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
PlayAwhile
Jul 20, 2015 11:36 AM
