Clinometer Idea
Old Apr 23, 2010 | 09:18 AM
aviator's Avatar
Thanks man wow that was fast!
Old Apr 23, 2010 | 09:31 AM
aviator's Avatar
Here's something I found,,, if you can trim the ring down to 2 5/8" it might work http://www.autometer.com/cat_mountsd...=49&mid=8&pg=0
there are also chrome and black ones.
The pods all seem to be for 2 1/16" gauges which probably would'nt work given the size of the clinometer.
Here's another option which might be adaptable to the larger cutout needed http://www.glowshiftdirect.com/Unive...-Dash-Pod.aspx
Old Apr 23, 2010 | 01:17 PM
Levis Pennae's Avatar
On a related note, why do compasses always point north to the dash?
Old Apr 23, 2010 | 01:47 PM
tumor21's Avatar
Ebay, $17.00
http://cgi.ebay.com/Pitch-and-Roll-L...item35a84a70a9
Old Apr 23, 2010 | 02:50 PM
  #25
stormin94's Avatar
I kinda like the Mitsu one. I bet you could pop out the other two gauges and put in other ones if you want. Maybe a water/tranny temp gauge, or a small aftermarket tach( for all you non SR5 guys/gals). Cool idea. I can never find the Toyota clinometers at Pick N Pull, and everyone that sells them wants $120 for them.
Thanks for the idea.
Old Apr 23, 2010 | 02:52 PM
  #26
stormin94's Avatar
Originally Posted by se7enine
You can find a bunch of those in the old Mitsubishi Raiders for 5 bucks at the Pick n Pull. I got one. It doesn't look as good but it will work and can be mounted where you want really.
What's the gauge on the left?
Old Apr 23, 2010 | 04:58 PM
  #27
se7enine's Avatar
Oil gauge is on the left. I have a couple extra horizon gauges minus everything else if you want one? No charge.
Old Apr 24, 2010 | 08:59 AM
  #28
sportbiker929's Avatar
what is one out of an 87 Runner in Gray worth?
Old Apr 24, 2010 | 10:25 AM
  #29
streetlancer's Avatar
You mean the inclometer; A lot
But i got lucky and found one at a pick-n-pull from an 87 Runner Gray in great condition for $20!!
Old Apr 24, 2010 | 10:33 AM
  #30
yep, i can get one for $25 bucks. Maybe i should.
Old Apr 24, 2010 | 06:04 PM
  #31
rattlewagon's Avatar
they go for a couple hundred on ebay.....it would be a good investment.
Old Apr 25, 2010 | 12:38 AM
  #32
ldivinag's Avatar
or for those with iPhones/itouches....
you can get a few clinometer apps out there.
a couple are a buck each.
from
http://itunes.apple.com/app/inclinom...309482204?mt=8
another one i got is called LandMeter where you can either set it for landscape or portrait and each gauge can be zeroed out individually.
one that cost 2 bucks:
http://www.offroadmeter.com/
kinda dont like this one due to the fact that the roll image is from the front of the vehicle, instead from the rear. when you roll to the left, the image on the screen, rolls to the right.
but i wrote the author some comments to see if they could redo it...
Old Apr 25, 2010 | 06:49 AM
  #33
thx man
Old Apr 26, 2010 | 12:38 PM
  #34
aviator's Avatar
nice apps except the image is of a heep...
Old Apr 26, 2010 | 12:47 PM
  #35
paynemw's Avatar
I'm all about this! mine mine mine mine!
corey519
Aug 12, 2015 11:12 AM
Up&Down
Aug 11, 2015 10:04 AM
Bawlzdeep
Aug 2, 2015 08:35 PM
Sr5crawler
Jul 31, 2015 12:32 PM
PlayAwhile
Jul 20, 2015 11:36 AM
