chirping noise--wheel bearing? tie rod end?
Old Jun 13, 2009 | 03:56 PM
Texas91Runner's Avatar
I own a 1991 4Runner 3.0 a/t. I've noticed for a while now that the front left area of the vehicle has been producing an odd chirping noise every time I hit a bump or travel on a rough road. It seems like it's coming from the front driver's side wheel well.
Any thoughts?
Old Jun 13, 2009 | 08:43 PM
desertcamper67's Avatar
Maybe a bad or missing sway bar bushing, lower control arm bushing, plastic inner fender loose or missing a screw, bent metal dust cover on shock.
Try bouncing on the left front fender and see if you can reproduce the noise and then track it down.
Old Jun 13, 2009 | 10:19 PM
Jay351's Avatar
Jack up each front wheel one at a time. Check for play in the wheel bearings, balljoints and steering parts.
Make sure its not just something simple
Old Jun 17, 2009 | 10:05 PM
I haven't had time or daylight to check it out thoroughly yet, but the problem is really getting worse..
I have a hunch that it's the control arm bushings..the sway bar bushings look fine.
I can't really produce the noise with putting my weight on it.
bigjstang
Jun 2, 2025 03:56 PM
krimsonone
Sep 13, 2024 09:33 AM
Sep 4, 2015 09:27 AM
Lochsa
Aug 2, 2015 02:51 PM
ripp96
Jul 25, 2015 02:32 PM
