chevy spring swap no good compress rear
Old Nov 25, 2009 | 07:52 AM
4x4runr's Avatar
they arent at full flex though since the tire is still hitting the body, when i did the latest trim i gained an additional 4-5 inces up travel....
if you can afford it, 4link it
cheers
Old Nov 25, 2009 | 12:04 PM
scrowley's Avatar
that is sick!. I have to do this. did you do a custom fab or use a kit? what springs? can you send a pic of underneath from the rear so i can see what is going on in your setp. pics of front mounting locations. I know i would never get that out of a spring. Is it as heavy duty as using springs. reliability wise? thanks for the pics.
cheers
Old Nov 25, 2009 | 12:06 PM
scrowley's Avatar
also what front springs are those.
Old Nov 25, 2009 | 12:15 PM
camo31_10.50's Avatar
that's a lotttt of flexxx...im jealous
Old Nov 25, 2009 | 03:09 PM
  #25
scrowley's Avatar
sure is
Old Nov 25, 2009 | 10:44 PM
  #26
Jay351's Avatar
4 link would be ideal, flexy and nice ride... so much money tho!
Old Nov 26, 2009 | 03:37 AM
  #27
4x4runr's Avatar
It was a custom build(my friends shop)
The springs are Stock TJ coils...dont remember the year....
I think links are stronger...my opinion(if your're worried about strenght get chromoly). I broke the leave springs that you see it on, cracked in half. It was a sper lift 6.5" lift springs....i took out some leaves to drop the hieght which caused the leaf to break after a few runs in the trails. My new leaves are trail gear 3".
Link set up reliable? Definately, and has a smoother ride, it's quiter and handles like a Lexus in the trails no joke lol.
Anyway, here are some pics of the rear build...not the best angles :S
The bottom link was sleeved for extra strength . the inner is 1.25" and the sleeve is 1.75" i believe(sorry it was so long ago )
This is not a cheap build.... like i said if you can afford, 4link it. and if i could, i'll link the front
Old Nov 26, 2009 | 08:06 AM
  #28
scrowley's Avatar
thanks for the pics. what makes it so expensive?? link ends, steel, etc. the custom work looks straight forward I think. How did you come up with all of your measurements and such. looks great. with all that steel on the rearend that think is a tank. Looks like the exhaust would be tuff to run after this. nice job. back in the day when I was into lowrider trucks I used to 4 link the rears with airbags. it was easy. I did buy kits for this though. thanks
Old Nov 26, 2009 | 10:59 AM
  #29
tc's Avatar
tc
Here's the buld thread on mine
https://www.yotatech.com/forums/f116...thread-153382/
I went pretty much top of the line, and it was $1000 without springs/shocks.
Fabrication-wise, I don't think it's much more or harder work than doing a leaf swap.
Old Nov 26, 2009 | 01:35 PM
  #30
4x4runr's Avatar
Materials is expensive, but if you do the work yourself it would be much cheaper!! DO IT!!!
As for the measurements, the shop came up with all of them. For the exhaust, there is actually a lot of room since i removed the gas tank.
Old Nov 27, 2009 | 07:21 AM
  #31
scrowley's Avatar
looks great. that is some crazy flex. that thing must go anywhere!! got any vids?
Old Nov 27, 2009 | 08:50 AM
  #32
rattlewagon's Avatar
i would take out that over load spring. you might gain some up travel that way.
Old Nov 27, 2009 | 09:47 AM
  #33
tc's Avatar
tc
Got any more pictures of this crossmember and what you did so it would clear the driveshaft? (cuz obviously, this ain't gonna work!)
Old Nov 27, 2009 | 10:18 AM
  #34
MuddfreaksOffroad's Avatar
thats pretty intense i like that set up, lol
Old Nov 27, 2009 | 04:03 PM
  #35
scrowley's Avatar
if i do that i would only have the 2 springs left. Wouldnt they break or wear out extremelly fast? OR is the the same as taking the overload of any spring pack.. the overload is only working when it is almost flat?
Looked at the other pic and seems like they used a 12" or so straight extension off the tcase that connects to the u joint..
Old Nov 28, 2009 | 08:06 PM
  #36
4x4runr's Avatar
No extension, I'll post a pic as soon as I can get camera :S.
Old Nov 28, 2009 | 09:40 PM
  #37
Silver_Truck's Avatar
hey silver truck dude...i see a problem with your truck.....
you aint got no shocks dude...........
haha yes...that was when i was measuring for shocks...I'll try and find another shot or get some for you when I roll the truck back out of the shop
1badyota350
Jun 28, 2015 06:50 AM
cchinny
Jun 25, 2015 08:11 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
infinityisfive
Jun 16, 2015 06:51 PM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
