check engine light
Old Nov 6, 2009 | 11:34 AM
jrlydy's Avatar
check engine light
throwing a code 12 and 22 engine speed (rpm)sensor circuit and ect sensor circuit so any help getting me back on the road would be greatly appreciated just had the the hole top end rebuilt so dont want to mess any thing up.the heads pressure tested shaved all new gaskets water pump,timing belt,valve's reseated,water pump ......
Old Nov 7, 2009 | 07:59 AM
thook's Avatar
Hmmmm..........well, you're going to have to mess with something. And, most likely it's electrical.
Might start by checking the connectors, first. Check the wires. Then, I'd test the components.......even at the ECU. Poor connections just after a rebuild is pretty common, though.
Old Nov 7, 2009 | 01:28 PM
jrlydy's Avatar
thank you it was the ect clip runs great know
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
