Changed MC, bled brakes, LSPV will not bleed
Old Aug 4, 2010 | 06:32 PM
PCE91V64x4's Avatar
I put in a new master cylinder, bled all 4 wheels (driver rear, pass rear, pass front, driver front), and then the LSPV. The LSPV will not bleed, no fluid will flow out of it (but all 4 wheels bled just fine). The brakes are ok but not as firm as they should be when I test drove it.
Any ideas or just keep on bleeding them in order until it works? I did it twice so far.
Thanks,
Scott
Old Aug 4, 2010 | 06:53 PM
thook's Avatar
If the LSPV won't bleed, it's clogged. Probably at the bleeder valve itself. You'll need to take the bleeder out and clean it with some brake cleaner and a thin wire or pick. If that won't do it, you may need to disassemble the LSPV. Not hard to do. But, see if cleaning the bleeder works, first.
Old Aug 5, 2010 | 02:41 AM
PCE91V64x4's Avatar
ok, will do that. When I have changed the brake fluid in the past I have not had this problem (no fluid) but I have had trouble getting all the air out of the LSPV so maybe whatever blockage is in there has just gotten worse.
Old Aug 5, 2010 | 07:05 AM
thook's Avatar
Yeah, over time moisture can build up in there. Well, in the entire system, really. And, so rust and crud tends to deposit in the nooks and crannies of everything. Brake fluid is hydroscopic.
If you can get someone to help, have someone pump the brake while you watch the LSPV. Pull the rubber boot at the bottom back enough to see the little end of the valve. It should be moving out when the brake is applied and back up when released. If it isn't moving, the valve's not even working.
http://www.autoshop101.com/forms/brake08.pdf
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
Whatever123
Sep 30, 2015 12:12 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
