Can anyone ID this Dana 60 hub seal? I'll send you a six-pack
Old Oct 30, 2015 | 04:54 PM
v_man's Avatar
I'm having a devil of a time figuring out what hub seal I need for my rear Dana 60 axle. I am leaking diff oil out out the rear tube onto my rotors, brakes, and tires. yuck...
I pulled the axle shaft out and I can see the hub seal, but I cannnot figure out the part number to replace it???
If anyone can point me in the right direction, you got some cold ones coming your way...
It's a Dana 60 rear , disc brake conversion, 30 spline shaft....side note: how bad is it to be leaking diff oil onto brake parts? I've heard eventually you will ruin your pads and rotors, but so far I see no ill-effects...
Old Oct 31, 2015 | 12:13 AM
wyoming9's Avatar
Red face
Pull it apart and measure every thing
The ID the OD the thickness of the seal.
Go to your local Seals`rus and have them match to what is close because your measurements may be off
About the only way if the numbers are gone from the seal.
Then you have no real clue just what that axle housing started out in.
Gear oil will make your brake pads grab and depending on your brake use could start on fire.
Scatterbrain
Sep 27, 2015 08:24 AM
theBAYsic
Sep 16, 2015 05:21 AM
elaketiger
Sep 14, 2015 09:58 AM
Scatterbrain
Sep 3, 2015 06:46 PM
4x422r
Aug 18, 2015 05:33 AM
