Burned hole in axle tube
I ordered some new shocks for the rear of my truck and decided to relocate the lower shock mounts. It has a trail gear six inch rear lift on it. U bolt flip from trail gear also. Shock mounts were on top of the housing. Moved to add more shock travel. Well anyway when using the plasma to cut of the right mount I ended up burning a hole in the tube. After much yelling and cursing I calmed down and determined my options.
1. Look for a new axle housing and swap everything over
2 Tear apart the axle remove third member axle shafts etc weld it up and flush it out
3. weld it up and just run it a second down the road and drain the fluid.
So I ended up going with option 3 right wrong or indifferent. I welded it up and finished the shock relocation and some brake line rerouting and took it down the road and back parked it and drained the fluid. Seems like the magnetic plug caught most of the junk, not too much actually. Filled it back up and will run it again for a bit and then probably drain it.
Anyone else do any boneheaded thing like this?
I once put oil in my radiator lol
Just finishing up a rebuild and topping off fluids. My oil was in a BLACK 5quart jug and coolant was in a BLACK 1gallon jug. Was switching back and forth waiting for levels to settle and poured the oil in my brand new radiator.
I knew it right away and after I quit cursing and regathered myself I drained and flushed it multiple times and off to the parts store for more coolant I was. Easily my biggest bonehead move
Blamalam
Mar 12, 2022 07:34 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
priest16
15
Aug 6, 2015 07:43 AM
WTB[MidWest]: Looking for 5spd harness, front axle- 1990 truck
dfarr67
Jul 30, 2015 07:08 AM
