Bumper question
Old Mar 21, 2020 | 07:50 PM
Chase Forman's Avatar
Bumper question
I was looking into getting a tube bumper for 1991 Toyota pickup. The one made for it is like 500 but I noticed this one for 100 https://www.ebay.com/itm/143537257859 how hard would it be to convert it? Anyone do this before?
Old Mar 21, 2020 | 09:15 PM
Ezrider_92356's Avatar
if you have a welder a drill and grinder not a problem.
i have a tube front bumper wasn't originally for a Toyota cut the mounts off and made mounts to work just re did it again because i used to have a body lift on this truck does not have a body lift anymore. if you can position the bumper on jack stands or something to place it where you want it then just look at it and figure out where your brackets need to go to where you want to bolt it on then you can make them tack them in place pull the bumper back off and weld it up. probably a couple hour project.
if you don't have a welder im sure a shop could do it for you but that cost might offset buying one that's made for it to start with.
jbomb314
Ozarks
Jul 12, 2016 07:01 PM
drew303
Dec 8, 2012 05:09 PM
antneee
Oct 30, 2011 07:40 PM
88wildrunner
May 20, 2007 09:51 PM
