Bubbly noise in my heater core
Old Oct 13, 2007 | 02:44 AM
BrownsfaninMN's Avatar
My 94 V6 has a bubbling noise when I have the heater on and when I accelerate, is there a way I can vent this trapped air? Thanks.
Old Oct 13, 2007 | 03:09 AM
TORTIS's Avatar
i think you are supposed to start vehicle, take off radiator cap, turn on heater. this allows air to escape. are you losing fluid? i know you know, but don't take the radiator cap off while engine is hot.
Old Oct 13, 2007 | 11:33 AM
n4ynu1010's Avatar
Air in Cooling System/Air Pocket
Yeah I have read some threads outside of people turning heat on and getting air out that way (the normal method) , that also they would park on a hill or put the vehicle on ramps - never done that but ................Turn your heat on (don't need fan by the way) , let truck get up to temp and fill , if you want to make sure you have the air pockets out then raise rpm a bit which will increase flow and remove some of the more stubborn air commies and make sure you have coolant in your overfill/recovery tank , if all that doesn't work then I would say use the incline method .
dbd6604
Oct 11, 2015 05:30 PM
YotaPagota
Sep 20, 2015 06:24 PM
LotOMiles
Sep 14, 2015 11:45 PM
Kreedy1
Sep 8, 2015 06:33 PM
--Oz--
Sep 6, 2015 01:06 AM
