Broken rear differential cover bolt
Old Apr 30, 2016 | 10:08 PM
Allysa Chandler's Avatar
How do I get it out
Old Apr 30, 2016 | 11:25 PM
wyoming9's Avatar
Red face
Depends on just how you managed to break it.
Is it broke off below the surface ??
enough left to weld a nut to ??
Different methods depending on just how you broke it.
Old May 1, 2016 | 04:09 AM
rattlewagon's Avatar
Pictures would help. And which bolt? Because the diff cover is welded on. Year make and model will help.
But you could always drill it out, then re tap if needed to or use an easy out. Heat will always be your friend. Once you get the diff out can is there enough room to get vice grips on it?
Welcome to the forum. But help us help you. The more details you can provide the better. Remember, we cant see what your looking at.
Old May 1, 2016 | 09:58 AM
dropzone's Avatar
Fossilized
Pull the entire third member out, apply vice grips land turn to the left.
it is a stud
RatOmeter
Dec 24, 2025 01:01 PM
04sport4x4
13
Mar 22, 2016 01:56 PM
BarefootGeologist
Feb 15, 2016 06:01 AM
77RogueRunner
Feb 14, 2016 07:06 PM
punks_is_4x4
Feb 12, 2016 02:28 AM
