Brakes 89 pickup 4x4
Old Oct 28, 2006 | 05:47 PM
Yotapup's Avatar
I have been through my brakes ,bled them and made sure all calipers are working. My problem started with a soft brake pedal. I assumed air in the lines,bled some air out of lines but now i am experiencing a different problem:When I press brake pedal it is firm but I get no braking action ,then a split second later the pedal gives and finally I have brakes.
I am thinking a bad master cylinder. Any ideas?
Old Oct 28, 2006 | 07:20 PM
mtnfreak's Avatar
I'll go along with bad MC, but I'd like to know a couple of things: Do you get the same problem with the engine off? Have you checked the booster?
Old Oct 28, 2006 | 07:37 PM
Yotapup's Avatar
While bleeding the brakes I got a full brake pedal on the passenger rear temporarily and then that never came back. Other than that time I cannot get a full brake pedal( compared it to my 94 yota). It acts like some kind of bleed by in the system.
I haven.t checked the booster b/c I didnt think that would cause a problem unless engine were running.I will definitely check her out in the morning though.
Old Oct 29, 2006 | 11:21 AM
trythis's Avatar
look into the FSM, it has instructions on how to test for the booster.
My MC went bad and I could tell because the truck would start to move a when I was sitting at a light. It's an automatic, but the peddle would sink slowly to the floor. That's the sign of bad MC seals letting fluid pass through.
Old Oct 29, 2006 | 04:54 PM
Yotapup's Avatar
Bad MC was the culprit. when I pulled the reservoir I saw rust !.New MC and she is braking like new. Thanks for the input.
Aleeex_u
Jun 5, 2016 06:52 PM
rondogracing
25
Dec 11, 2015 07:26 AM
Peach
Jul 3, 2015 09:30 AM
bprice0077
Jun 25, 2015 07:36 AM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
